Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
Register Forums FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 07-09-2008, 11:58 PM   #1
swiest152
Senior Member
swiest152's Avatar
Bikes: SV
Send a message via AIM to swiest152 Send a message via MSN to swiest152 Send a message via Yahoo to swiest152 Send a message via Skype™ to swiest152
Rear Wheel Thread
Rear Wheel Swaps.
CBR F3 Rear Wheel
Wheel Years: 1994-1998
Width: 5.0"
Tiresize: 170-180
Rotor Size: 220mm
Weight:
Parts Needed: Captured Spacer Kits
Modification needed: Bevel top 10mm of brake pad or buy a Galfer oversize 240mm rotor. Galfer Part number: DF007W
1993-1995 GSXR750, 93-98 GSXR 1100, 94-97 RF900 -Rear Wheel
Width: 5.5"
TireSize: 180-190
Weight:
Parts: needed: Spacer Kit (TWF no longer makes)
1: Machine Caliper Hanger
2: 525 Sprocket or 520 conversion.
Bandit 1200 Rear Wheel
Wheel Years: 1995-2005
Width: 5.5"
TireSize: 180-190
Weight:
Parts Needed: Spacer Kit (TWF no longer makes)
2: 525 sprocket or 520 conversion.
Newer GSXR wheel (sv1000 wheel is the same)
Wheel Years: 2001-2005 & 06-07 (06-07 are lighter and look different)
Width: 5.5" (1000s are 6.0")
TireSize: 180-200
Weight:
Parts Needed:
Modification needed: Wheel (possibly the cush drive/rubbers/brake caliper mounting bracket on the 01-05 wheels) , and new spacers need to be made.
As of now there are no kits out for this conversion.
(1996+ 750&600 and all GSXR/TL/sv 1000 wheels will all require the same amount of work)
Blair's from SV racing parts EMAIL
Link to SV Racing parts HERE (Pit Bull, PBI, and Sprocket Specialists dealer)
Link to TWF (Twin Works Factory) HERE
Please fill in the blanks or correct me. I will update this post when someone has new information.
*updated with Sam's info* 3/18/09
swiest152 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-10-2008, 01:18 AM   #2
sv-racing-parts
sv-racing-parts's Avatar
Bikes: SV650 Curvy
Miles Kms: Not Enough, Not Nearly Enough for me, ever
Thumbs up Rear Wheel Thread
Quote:
Originally Posted by swiest152 View Post
Post everything you know about different rear wheel swaps for 650s.
CBR F3 Rear Wheel
Width: 5.0"
Tiresize: 180
Parts Needed:
Modification needed: SV Racing Parts Captured Spacer Kit. Easy install, Excellent Fit.
GSXR750 Rear Wheel
Wheel Years: 1993-1995
Width: 5.5"
TireSize: 180
2: 530 chain or 520 conversion.
Wheel Years: 1996-2000
Width: 5.5"
TireSize: 180
F3 Wheel Conversion is Simple and Easy with the SV Racing Parts, Captured Spacer Kits, allows you to run up to andincluding 180 Rear Tires,
Fit is Excellent,
Enjoy the ride, and best regards,
Blair
sv-racing-parts is offline   Reply With Quote
Old 07-10-2008, 08:22 AM   #3
orangegilly
Site Supporter
orangegilly's Avatar
Bikes: 2000 SV650
Miles Kms: 25k+
Re: Rear Wheel Thread
The 93-98 GSXR 1100 wheels are the same as the 93-95 750 wheels, and require the same mods to fit. A p/n search on ronayers.com shows that the 94-97 RF900 used the same wheel as well.
I don't think you can run a 530 rear sprocket on the SV due to clearance issues between the swingarm and the sprocket bolts.
The best part about these wheels is that they are visually identical to the 1st gen SV wheels.
The F3 wheel can run either the 170 (preferred for that wheel) or a 180.
orangegilly is offline   Reply With Quote
Old 07-10-2008, 08:27 AM   #4
swiest152
Senior Member
swiest152's Avatar
Bikes: SV
Thanks gill.
MullerJD had his 530 sprocket modified so it was a 525. not sure about the details.
Old 07-10-2008, 08:38 AM   #5
orangegilly
Site Supporter
Bikes: 2000 SV650
Miles Kms: 25k+
Thanks gill.
Correct, meaning he had it machined to be the thickness of a 525. I had the same done to the Renthal sprocket I'm running now, but I recently discovered that AFAM is now making a 520 sprocket for that rear wheel in sizes from 38-50. One of the biggest drawbacks to this point was that the rear sprockets were either only available from a couple sources (Vortex and Sprocket Specialists) or were really expensive (Sidewinder). I'll probably be switching to an AFAM next spring, as I'll be pretty close to needing a new chain by then.
Old 07-10-2008, 10:31 AM   #6
sv-racing-parts
Bikes: SV650 Curvy
Quote:
I also have those sprockets available to me for customers, with the combination Chain and Sprocket Packages I am providing as well,
The rear sprockets are Black, in Hard Anodized Aluminum, Super Light Weight with Superb Life for wear and performance,
Blair
Old 07-10-2008, 10:38 AM   #7
swiest152
Senior Member
swiest152's Avatar
Bikes: SV
Blair
the 520 or 525 sprockets?
Old 07-10-2008, 11:16 AM   #8
sv-racing-parts
Bikes: SV650 Curvy
Thumbs up Re: Rear Wheel Thread
I do 520 and 525 Sprockets,
Great Gold Chain as well,
Let me know if I can ever help you out, by emailing me at b.layton@svracingparts.com
Blair
Old 07-10-2008, 11:23 AM   #9
thejimdaddy
Titanium Member
thejimdaddy's Avatar
Bikes: 2007 GSXR Sebben-fiddy, 2007 6seventy5
Miles Kms: i don't ride it
Sprocket Specialists will make a 525 sprocket for any application, in aluminum only, and they charge an extra $7 i believe, that is from a few years ago tho
__________________
Quote:
Originally Posted by silversx80 View Post
TJD is full of win. It came preloaded on his hard drive.
Quote:
Originally Posted by AlexJ View Post
TJD takes care of his ladies!
thejimdaddy is offline   Reply With Quote
Old 07-10-2008, 11:30 AM   #10
buzzmanrm
Senior Member
buzzmanrm's Avatar
Bikes: 05 650
Miles Kms: 12500 miles
Blair I need a front sprocket and chain pretty quick for the 05' SV. I changed the rear for a 525 when I got the wheel about 2000 miles ago. My front sprocket looks good no curling but I want to change with the chain. As I am stretched to the last two lines on the adjuster. I want a rivet link chain and a steel sprocket in 525. thanks.
Swiest I got a F3 wheel on my 2nd gen, the spacers pretty much stay in place when you change rubber so you can swap rims in under 20 minutes with hand tools. I could probably do it in 5 minutes with a little practice. The kit works nice and if you want new bearings the part number is Timken 204's they are 15 each at Autozone.
I run a Michelin 170 and feel really comfortable on edge. Grip is great and the profile is nice I will be trying a 180 Pirelli Rosso next.
I have heard that RC51 forks fit in the GSXR triples which would allow you to run matching rims then Only a rumor. Blair?
buzzmanrm is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
©1999-2009 SVRIDER.com.
