| Forums | Register | FAQ | Gallery | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| SVRider Motorcycling Forum Our main message forum catering to the Suzuki SV and general motorcycle chatter. |
Thread Tools | Display Modes |
#1 |
Junior Member
Bikes: 2004 SV650S
Miles Kms: 4200
Finaly a detaled How To, Swap clipons for handlebars
Here it is took me several hours to type it and get it right, This is a highly detaled how to, for swaping your stock SV650S clip-on handlebars to SV650 Naked handlebars.
All pictures are at the bottom of the second post. For anyone who hates having a sore back, wrists ect. this swap is for you, the 2 inches up and 1 inch back is worth every penny of the aproxmit $300 price tag. Please note this information is intended for the 2003+ SV650S models To start I would like to qualify myself, I have preformed the swap of SV650N (naked) handlebars on to an SV650S (2003+ model year) on my own bike as well as max_boost’s bike (pictures of his bike are in the 4 post), both with very successful outcomes, although I am no mechanic. Disclaimer: Everything stated herein is for reference and is accurate to my knowledge. However I am sure there are things that I am unaware of and I do not make any representation that this information is complete or totally accurate. Therefore any user of this information must be responsible for any outcomes and your own actions. As this guide is not all inclusive to performing this swap, you should have a good mechanical ability as you will be removing and replacing many key parts of the bike including brakes, ignition, steering components ect. If you do not have this ability don’t try this or find your self someone who does have the ability. In order to swap the clipons on a SV650S to the handlebars of the SV650N you will need the following items.
The following items are recommended but not required
As for the wind screen there is enough clearance and you do not need to cut or modify it in any way. I have heard of people re-using the SV650S brake lines and clutch cables but have no idea how they just don’t seem long enough, and I prefer a seamless final product that I know I won’t have problems with. As a side note, you will need to remove the gas tank and this is made much easer with as little gas in the tank as possible. On my personal bike I went with all of the above with exception of the longer throttle cables which to some extent I regret (but not enough to change them out now). On max_boost’s bike he decided to go with all of the above. The handlebars and clutch cable I ordered from www.babbittsonline.com (good prices and service), upper triple tree and bar clamps came from e-bay (these can be hard to find at times) my stainless lines I got through JP Cycles, security torx from Home Depot (you must buy a hole screwdriver set to get the one bit you need), the bleeding kit you can get at any auto parts store and finally my common since came from my brother. Once you have all your parts you can begin. Stripping the bike
Option 1
Option 2
Stripping the bike – Part 2
See next post for rebulding the bike and pictures. Last edited by kc8rev : 05-11-2008 at 08:32 AM. Reason: Adding pictures |
| Sponsored Links | |
Advertisement |
#2 |
Junior Member
Bikes: 2004 SV650S
Miles Kms: 4200
Re: Finaly a detaled How To, Swap clipons for handlebars
Re-building the bike
After your road test you may notice that the windscreen is not quite as effective, being you are sitting up more. I replaced my windscreen with a Givi, the added 2 inches helps a lot, particularly on the expressway. As a side note when replacing the windscreen you will already have the front cowling off, so just do your bike the favor and change the coolant that you have been neglecting for years. If you notice any major mistakes or have preformed this swap your self and would like to correct or add something please let me know and I will make corrections as needed. UPDATE: I'm posting a PM by MoDaddy with the parts he used to preform his swap just incase anyone wants to do it a little differently. "I used Outlaw risers, Moose Racing MX bars, Galfer brake lines, OEM SVN clutch cable & stock throttle cables (rerouted)." P.S. I'm glad to see that this post is making pepole's swap go easyer and hopefully it's used for years to come. Thanks kc8rev 10-28-08 ![]() ![]() ![]() ![]() ![]() ![]() Last edited by kc8rev : 10-28-2008 at 06:14 PM. Reason: Update |
#3 | |
Supporting Member
Bikes: 2001 SV650S
Miles Kms: ~10,000mi
Quote:
Other than that though, looks pretty well written. |
#4 |
Member
Bikes: Suzuki GSX-R750
Miles Kms: 8,500
I don't have detailed pics but here are a few of my bike. Thanks again for the help.
__________________
2004 GSX-R750
#5 |
Senior Member
Bikes: '99 SV650
Miles Kms: More than yesterday
Nice write up.
IMHO- Those bars just don't look right on the S. They don't look bad, just not quite right. Although I've always been more of a function over fashion kinda guy myself so I can understand why you would make the swap. |
#6 |
Senior Member
Bikes: '07 SV650s '98 Yamaha RXZ-135
Great write up. I'm about to do the same swap myself... The only part i'm lacking at the moment is the throttle cable. Thanks for all the tips. I was wondering how I was going to mount the resevoir, but you have answered my question. Thanks a bunch!
I didn't realize it was such a pain to get the throttle cables off. I'll be sure to set enough time aside to do that.
__________________
-Andy |
#7 |
Senior Member
Very nice job.
I usually leave it to others here to be the spelling/grammar police, but since I see this destined for the Tips and Tricks section (and because it's too darn funny to pass up), I'll correct one little faux pas: "Disclaimer: Everything stated herein is for reverence.... Unless you mean that this write-up is so awesome that we should all bow down to you (hey, it's good, but it's not that good), I think you mean:"Disclaimer: Everything stated herein is for reference...." Again, nice work. |
#8 |
Site Supporter
Bikes: (K3SV650N Custom) now: 2008 KTM Duke 690
Miles Kms: 18,000 mi. (Duke)
I have an upper triple and bar holders/bars on the for sale page if anyone is doing this mod.
__________________
THE THUMPER SQUAD '08 KTM Duke 690 "Rotard" My Zazen: A streaming landscape and tilted horizon. |
#9 |
Junior Member
Nice write up, i did the same thing to my girl friends 05 SV650S as she didn't like the clip-on ride position.
I wish i would have such a great write up to follow; however like you i trudged thru it on my own. I got a set of 3" longer cables from Motion Pro and picked up the Triple Tree off Ebay for $50. ![]() ![]() |
#10 |
Senior Member
Nice work!
I did the same swap a couple of months ago. My wrists appreciate the comfy new riding position. Great idea for attaching the brake fluid reservoir; I've been forgetting to permanently mount mine (it's been zip-tied and I'd forgotten about it). I will give your method a shot. . |
| Thread Tools | |
| Display Modes | |
