Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Marketplace > Product Reviews
Forums Register FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read
Product Reviews Self explanatory. Bike related posts only, please.
Reply
Thread Tools Display Modes
Old 07-19-2007, 09:08 AM   #1
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
Miles Kms: ODO 01723
Trail Tech Vapor, Vapor Gauge, Vapor Install, Vapor....
<Don't mind the title boys it's to help the search engine and noobs locate this thread and info cause retyping this every PM is killing me!!!>
Okay so let's begin again,...... (and again today 3/29/08 cause my stupid dumb ass deleted the pics from my photobucket account that are needed for this thread.)
I got their #75-300 Suzuki kit with the dashboard #022-PDA and 1" water temp sensor with 28" lead #7500-3076. However Jeapardy98 heard/thinks the temp sensor that comes in the kit can be wired into the OEM temp sensor in the SV radiator. I don't know if this will work so you'll have to ask him or just call Trail Tech, a tech will gladly answer all your questions as they did mine. 360.687.4530 .
>>> 05.01.08 Update!! There is now an SV650 ( 99-08 ) specific kit available from Trail Tech, Part Number: 75-600, Price: $124.95 YAY!!!<<<
http://www.trailtech.net/75-300.html
bracket made and mounted in stock gauge mounting bolts. If you can do better have at it!!!
Hard wired it into the OEM wiring to keep the OEM harness* connectors for ease of removal. Please see wiring diagram in Suzuki service manual for wire color codes page 7-32. Just figure out which lights you want from the 8 and then find the wire to connect it to.
*(Since my tach was busted in a fall I used the harness as the speedo wasn't sellable on its own. If your cluster is working it's worth $300 on ebay so don't cut the harness or plugs off, you may just have to hard wire the cluster into the bikes main harness or add some connectors if you want to make it removeable.)
1" Temp sensor cut into exit radiator hose you'll need to drain the coolant and remove hose. This is great time to flush and fill your system too.
I put this on the exit side to read the temp of the coolant going back into the engine just like the OEM temp sensor does, it's located just before the out flow tube FYI. Any where in the hose will work. I should have put it closer to the front cause of the sensors leads length (28") but you live and learn. And some black spray paint can be used if you want to make it blend in with the hose.
I ran the speedo pick up wire to the inside right of the rear wheel along the swing arm as I couldn't find a good place on the front wheel with the pick up wires configuration and distance to the magnet. This is out of the way, the lead was long enough and some auto epoxy on the pick up sensor and magnet are holding strong after many miles and washings. (The tape was just to hold it in place while the epoxy cured). ( I've seen some very creative front wheel pick up mountings since I first did mine so think outside the box folks and make it work!!)
For Tach install see below updated attachment...
Quote:
Okay so I got the Trail Tech Vapor back in Jan 07 and everyone knows about the jumpy eratic tach problems those of us with Vapors have. Well today I have finally fixed the problem and it's smooth as butter, doesn't drop out or go blank any more. It works like it suppose to!!!
So using their Yamaha Raptor 7000 ATV tach sensor wire (7000-1020) with a built in resistor (don't ask me how many ohms folk) I plugged the positive wire (red) directly into the positive output wire of the rear coil (white) to get the signal to the Vapor.
No need to wrap the sensor wire around the plug wire or anything, just plug it into the positive and it should be all good. Also you will need to set your pluses per revolution (PPr) to 1.0 and my pluse RPM is set to 0000. See pages 20 and 21 in the Vapor manual for setting this. If you don't have a manual call Trail Tech (360.687.4530)
I also made a couple of vids of the Vapor running so you can see that it does work. One is stationary just reving up in down the RPMs and the other is moving so sorry if you get motion sickness while watching it.
Stationary
==> http://www.youtube.com/watch?v=NOsOHizUIY0
Moving
==> http://www.youtube.com/watch?v=RA_JcPKpQjs
And I have a 1st gen SV folks, I have no idea if this fix will work on the 2nd gen, try it and see and if it doesn't work try something else.
And lastly if you want to set the Vapor odometer to read where your current speedo was here is how you do it.
Vapor ODO setting.
Removed at the request of Trail Tech ( 04.25.08 ). Please Contact them for specifics for this feature.
Installed and running.
==> http://trailtech.net/computers.html
I hope this answers all your questions.
__________________
Never seen the sun shine brighter
And it feels like me
On a good day...Oceanlab
Nexus242 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-19-2007, 07:04 PM   #2
duey
Member
duey's Avatar
Bikes: sv650k6 naked
Send a message via AIM to duey Send a message via MSN to duey
Re: Trail Tech Vapor, Vapor Gauge, Vapor Install, Vapor....
Great writeup Nex!
I'm in the process of installing mines in my 2nd gen, so maybe i'll make a diagram (and photo's) of the wiring for it. Other than that the basic concept is the same. I'll post up the pics as soon as i'm done installing it (may be awhile though got a good amount of trackdays the next 2 months lol).
duey is offline   Reply With Quote
Old 07-19-2007, 07:27 PM   #3
jeopardy98
Supporting Member
jeopardy98's Avatar
Bikes: '04 naked
Miles Kms: lots and lots
Send a message via AIM to jeopardy98
Hey thanks for that Nexus J/K. So did the power wire with the resistor solve your tach issues?
__________________
'04 SV650 Yellow w/ GSXR 1000 rear shock, .90 sonic springs and a few other goodies.
Quote:
Originally Posted by SexYonMySV View Post
I don't plan to go down, but if something does happen....well....you know.
jeopardy98 is offline   Reply With Quote
Old 07-24-2007, 11:52 AM   #4
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
Quote:
Not yet but I'm gonna lift the tank again and play around with how many times I wrap the wire and to which plug I wrap it to. Trail Tech says it should work and I believe it should work but making it 100% all the time beyond 3000rpms is proving to be a challenge.
__________________
Old 07-24-2007, 10:47 PM   #5
jeopardy98
Supporting Member
jeopardy98's Avatar
Bikes: '04 naked
Forget the wrap, just wire it directly to the stock tach wire and ground to the frame. That's how I have mine now but sometimes it jumps a little and it's off across the board by about 2000. I think I will call for one of those resistor power wires and just try it.
__________________
Old 07-24-2007, 10:57 PM   #6
NiceGuysFinishLast
Senior Member
NiceGuysFinishLast's Avatar
Bikes: '03 SV650S Copper, '02GS500 (For Sale!)
Miles Kms: 8900
Send a message via AIM to NiceGuysFinishLast Send a message via MSN to NiceGuysFinishLast Send a message via Yahoo to NiceGuysFinishLast
awesome write up. I think I'll get one of these if/when I get around to mounting the gixxer front end on my gs500, as the stock gauges will have to go!
__________________
'03 SV650S Copper - Yosh RS3 CF Slipon - Flushmount Front Signals - Competition Werkes FE w/ Flushmount - Custom Scratches and Bent Rearset from Lowside
Coming Soon - Racetech .85 Springs w/ 15w oil - GSXR Rear Shock - Tires
NiceGuysFinishLast is offline   Reply With Quote
Old 07-25-2007, 10:26 AM   #7
mrailing
Member
mrailing's Avatar
Bikes: 2007 Yamaha R1/2000 SV650 (for the track)
Send a message via ICQ to mrailing Send a message via AIM to mrailing Send a message via MSN to mrailing Send a message via Yahoo to mrailing
Nexus, again thanks for the information. I am getting ready to install my Vapor gauges and thought I would let you know the temp readings I found.
The cooling fan starts at 204.8 F and turns off at 195.8 F, and the Engine coolant temperature switch turns on at 239 F and off at 226.4 F. So I am planning on setting my warning light at 206 or 207 F (just above the fan kickon), and then my danger light at 227 F.
__________________
Michael
mrailing is offline   Reply With Quote
Old 07-28-2007, 11:03 PM   #8
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
Humm that sounds like the #4 wire in the OEM harness. Will have to give that a try on my next day off from work that I don't go back into work to do more work.
__________________
Old 03-29-2008, 09:43 AM   #9
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
bumping this crap back up to the top again.
__________________
Old 04-07-2008, 09:42 PM   #10
wrhammer
Junior Member
Bikes: SV650
Awesome pics Nexus! I have an SV coming this weekend to Trail Tech and we should have a dashboard milled up and a part created to hold the Vapor. Hoping we can install the indicator lights into it as well. I'll post the pics of the install and check with you guys for some feedback. Any suggestions let me know! Nows the time
Thanks, Wade H
wrhammer is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
©1999-2009 SVRIDER.com.
