Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > 03 + SV650 Tech
Register Forums FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read
03 + SV650 Tech Info, advice or questions specific to the 2003-up model SV650.
Reply
Thread Tools Display Modes
Old 11-03-2009, 07:24 PM   #1
hamogirl
Junior Member
Bikes: 2003 sv650s
Miles Kms: 6000
engine spins?
Ok. I've searched but can't seem to find a thread that sounds like my issue. I've got a 2003 SV650S. So I went to start my bike after it had been sitting for about a week and it began to turn over but then died out. I went to start it again and it sounds like something is spinning but not even attempting to turn over. I put the battery on a charger and put it back in but still nothing, just the spinning sound. I even took the battery to an advanced auto store and they checked it out and said it tested good. I've had the bike for about 8 months so I'm not sure how old the battery is. Also, the battery is apears to be sealed. I'm used to seeing the car batteries that can be filled with distilled water. Does this have anything to do with it? (Not being able to refill it)
hamogirl is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-03-2009, 07:55 PM   #2
CoryUT
Site Supporter
CoryUT's Avatar
Bikes: '02 Ducati ST4S (for sale), '07 Honda VFR800
Re: engine spins?
Sounds like your starter/sprag clutch. Have you tried push starting?
http://fiche.ronayers.com/Index.cfm/...TARTER_CLUTCH_
http://www.ronayers.com/browseparts....e.ronayers.com
It's a pretty straight-forward replacement, and a bad one is obvious when you handle it. It will fall apart in your hands.
__________________
Observations at 10
Smugmug
CoryUT is offline   Reply With Quote
Old 11-03-2009, 08:35 PM   #3
hamogirl
Junior Member
Bikes: 2003 sv650s
Miles Kms: 6000
Re: engine spins?
Thanks. I haven't tried to push start it yet. I've never done it before but I've been looking at some video's on youtube on how to do it. I'll try that next.
Old 11-03-2009, 10:19 PM   #4
jiari
Supporting Member
jiari's Avatar
Bikes: 2006 Red SV650S; 08 Specialized Tarmac Pro
Re: engine spins?
Similar thing happened to me on an 06. Went on a 2 week trip. Got on the bike for a quick spin and engine spun. Somehow, the front spark came loose. Tightend it up and away I went. It was working fine for about a month (I did the tappet clearance check a month before). Probably not the same thing, but it would take less than 20 minutes to check that the sparks are seated properly.
Some good ideas from the tread too.
http://forum.svrider.com/showthread.php?t=111300
__________________
2006 SVS->N, F3 Hybrid Fork, .85 sonics, '06 ZX10R shock, Leo Vince EVOII, DL handguards, Track Day Electronics GPI (w/aTRE), TPS, Motosliders, running lights
jiari is offline   Reply With Quote
Old 11-04-2009, 12:31 AM   #5
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Bikes: 03 SV650S; Custom Triumph Daytona
Re: engine spins?
It does indeed sound like the starter clutch (aka sprag)
Pull the stator cover to see what is going on when you operate the starter
D'Ecosse is online now   Reply With Quote
Old 11-04-2009, 07:04 AM   #6
hamogirl
Junior Member
Bikes: 2003 sv650s
Miles Kms: 6000
Re: engine spins?
Thanks for all the advice and the links. I'll check the spark plugs today. If it is actually the starter clutch and I have to replace it, is there a tutorial or pictures to show where it's located? I think I could do it myself if I just see a picture of where it is.
Old 11-04-2009, 10:56 AM   #7
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Re: engine spins?
I'm not sure if jiari's interpretation of 'spinning' is same as yours - or my perception of how you are describing the problem:
You press the starter button, can hear the electrical motor and something turning - however the engine itself is not cranking?
(I think jiari means his engine cranking but not firing)
If I described your situation correctly hamogirl, the spark plug connections would most certainly have nothing to do with that.
What does the starter clutch do?
It's a device that only allows engagement in one direction - so when you operate the starter motor, the gear engages and turns the crankshaft. However when the engine starts it will disengage from the starter gear so it does not transfer power back to the starter and thus keep the starter spinning. If the starter clutch is broken it will not transfer the power from the starter gear to the crankshaft and just spin over (as you describe) without engaging
The starter clutch is behind the generator rotor - biggest part of the job is just removing the rotor. You need a tool to hold the crank so you can remove the rotor nut.
As I suggest, first off, just pull the stator cover to see what's going on.
Get yourself a copy of the manual (search & you'll find some download sources) - see section 3-82.
Old 11-04-2009, 02:09 PM   #8
JonnyRocket
Junior Member
Bikes: 06 Suzuki SV650S, 99 Honda CBR1100XX
Miles Kms: 16000
Re: engine spins?
Get a Haynes manual. They usually have good descriptions and pictures of assembly and dis-assembly.
BTW, it is definitely not the spark plugs. It is probably not likely, but if the bike has been sitting outside, you may have some corrosion on the starter clutch rollers that is preventing them from engaging properly. A good cleaning may be all that is required.
__________________
"Is it time to race yet?"
JonnyRocket is offline   Reply With Quote
Old 12-21-2009, 07:25 PM   #9
hamogirl
Junior Member
Bikes: 2003 sv650s
Miles Kms: 6000
Re: engine spins?
so i finally found out the problem...it wasn't the starter clutch afterall...it was a little half moon shaped piece (i think it's called some type of "key") that broke off in that same area where the starter clutch is and was causing the spinning...so it will probably be another week or two before i'll be able to get the piece and put in some new oil....
Old 12-24-2009, 08:10 AM   #10
hamogirl
Junior Member
Bikes: 2003 sv650s
Miles Kms: 6000
Re: engine spins?
I've been all over town looking for that little key...a guy at napa auto parts gave me one but it's a hair to long so I may have to shave it down. I would like to find one that's the exact fit though. When I went to a motorcycle shop the owner told me he could order one but it doesn't specify a size. I have a few more places to check out before I go that route.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
©1999-2009 SVRIDER.com.
