| Forums | Register | FAQ | Gallery | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| 03 + SV650 Tech Info, advice or questions specific to the 2003-up model SV650. |
Thread Tools | Display Modes |
| Sponsored Links | |
Advertisement |
#3 |
Senior Member
Bikes: SV650/S, 2008
Miles Kms: 5k+
Re: velocity stacks
More airflow. Think of a vortex effect. Remember the old trick with the 2liter bottle of water? If you create a vortex with the bottle, the water empties out faster. Same concept. I have them, there is a difference but it is very small. I had some extra cash at the time so I figured why not. Never did a dyno so no facts to support it.
__________________
Life is to short. Use your time wisely and never let someone waste it. |
#4 |
Member
Re: velocity stacks
#7 |
Site Supporter
Bikes: 2005 sv650
Miles Kms: ~miles*.6214
Re: velocity stacks
seems like if the air flow is being restricted by the throttle, there is no benefit to be had..
I could be wrong. Explanation of why this would be helpful at mid throttle would be nice.
__________________
Best vid on the internets: here |
#9 |
Site Supporter
Bikes: 2005 sv650
Re: velocity stacks
you're killing me here.
why? I think of an engine as wanting air. The fact that the butterfly valves limit it's air intake is the only reason the engine doesn't run wide open and asplode. If you are limiting the air coming in with a butterfly valve, what benefit is having the air come in 'straighter' if you are just going to F it up with a butterfly valve??
__________________
#10 |
Member
Bikes: 2 wheeler
Miles Kms: Don't look down too often to check
Re: velocity stacks
This is what I understood from the wiki page that I just read...
One of the purposes of the stacks are to smooth out the airflow for the a more even and laminar flow in. with out the stack you have an abrupt change in wind direction and velocity which causes a "pinching" of the actual airflow into the pipe. This pinching will have a higher probability of causing turbulant flow inside the pipe and non uniform air flow past the butterfly valve...therefore making the air to fuel mixture unsteady. Also, the length of the tube will cause a variance in pressure at the point in which air bypasses the butterfly valves. I'm guessing (this is assuming that the pipe length can vary while riding...I may be wrong so take this with a grain of salt) that because the bike is never at the same velocity at any one point in time, that velocity outside the stack results in differrent initial pressures...therefore you have different pressures at the butterfly valve, if the length was constant...but if the length could vary the pressure at the butterfly valve could remain constant. I'm no expert...but that is my best guess |
| Thread Tools | |
| Display Modes | |
